How to direct access voice mail via PSTN call in
Discussion in '3CX Phone System - General' started by 5qg4, Jul 31, 2007.
  1. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    3CX Phone System v3.0.2328.0
    Voice Mail : 808
    I can using DR to access my voice mail via PSTN call in.
    Existing steps:
    1. PSTN call in our DR (801)
    2. press 808
    3. key extension number
    4. key password + #
    Now, I would like to setup DID direct map to VM (808). But failed. Since I cannot found 808 at "Route calls for this DID/DDI Number to".
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    I checked, you are right, when in DID rules, you cannot forward to 999. I am putting this up to be fixed. Should be in new version...
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Version 3CX Phone System Version3.1.2434.0 fixed this issue.
    Thank you very much :lol:
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Costas3CX,
    In DID rules, I can forward to 999 (My number is 808). However, the SIP call unable to ring the VM (999). The error as below:
    Please help to verify. May be it caused by my wrong setting.
