How to direct outgoing call to specific FXO Gateway port
Discussion in '3CX Phone System - General' started by junn, Oct 22, 2013.
  1. junn
    Oct 22, 2013
    I am using a Grandstream GXW4104 and connected 2 PSTN on port 1 and 2 and MagicJack on ports 3 and 4. Everything worked out fine but I wanted a certain dial code like "9" would use specific ports 1 and 2 and maybe "8" on ports 3 and 4 on the gateway.
    Is there a way to do this on the system?
    Thanks in advance for the help.
    10,573
    247
    You must split the ports into separate trunk groups unless your gateway is capable of selecting a port based on a prefix. I believe that some Grandstream gateways operate that way.
