How to disable dialtone
Discussion in 'Windows' started by magnusma, May 2, 2015.
  1. magnusma
    May 2, 2015
    How can I disable the tone when I i press dial numbers?
    They are useless and are so loud in my speakers.
    10,754
    286
    I tend to use the Android version more often and find that it has the same annoying habit. If I'm in a quiet room, the initial DTMF sounds, when dialling are quite noticeable to anyone nearby. I have not come across anything that disables that, and I agree, it is not necessary as a simple click sound would suffice. Perhaps someone from 3CX could comment, or, another Forum member has some suggestions.
    You might consider editing your subject line, to solicit more of a response, as the term "dialtone" has a different meaning compared to "DTMF tones", for most users
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Aside.. would be nice if the tones were DTMF again.. like in v6!...
