How to disable STUN-related communications?
Discussion in '3CX Phone System - General' started by VladislavA, Jun 15, 2007.
  1. VladislavA
    Jun 9, 2007
    30
  2. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    STUN std ports are UDP 3478 and 3479 just block it on firewall (if this is what you mean by disabling STUN-related communications)
    Marcin
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Disable STUN for all SIP phone set as well. After that your SIP phone at internet will unable to use this services. Unless all the things are setup at internet without NAT.
  4. VladislavA
    Jun 9, 2007
    30
    Thank you for the answers!
    I must define question more exactly. Can I disable 3CX STUN activity?
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,309
    Yes, you can
  6. VladislavA
    Jun 9, 2007
    30
  7. archie
    3CX Support
    Aug 18, 2006
    1,309
    1. By using advises above.
    2. By entering non-valid stun server's address
  8. VladislavA
    Jun 9, 2007
    30
    By using non-valid STUN IP address.... Hmm... I can't avoid undesirable network activity by this method.
  9. archie
    3CX Support
    Aug 18, 2006
    1,309
    If you set it to 127.0.0.1 -- you can.
