- Joined
- Jan 22, 2008
- Messages
- 12
- Reaction score
- 0
Is it possible to fully disable stun?
Its not needed in our setup as we have a public IP.
Ive tried to remove the stun entries, however we still get
[CM306002]: There is no valid STUN server specified! External IP can not be resolved.
in the log files.
I thought I had found a way round it by making all ips internal (that allows the registration to go through), but stops calls going out. Ive check and the firewall ports are opened, though the firewall checker wont run.
Regards
Paul Banks
in the log files.
Regards
Paul Banks
