How to display 3CX call reports in MS Dynamics CRM 2013?
Discussion in 'Windows' started by mbedenik, Nov 10, 2014.
  1. mbedenik
    Nov 10, 2014
    What I want is to instead of getting a call report on call reporting module on my phone system server, I want to reach the same one within MS Dynamics CRM 2013.
    Software that I use are Windows 7 64-bit, Dynamics CRM 2013 with installed 3CX CRM Integration Module, 3CX Phone System PRO.
    During the configuration of MS Dynamics CRM plugin I checked the checkbox "store call information in Microsoft Dynamics".
    Does that allow me to view 3CX call reports within Dynamics CRM 2013? And if yes, where I can find it?
    If above is not the case, is there any other solution to solve my request?
    I also tried to find 3CX API which provide that feature but nothing.
    Thanks in advance!
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    No.. it won't get you the call reporting into CRM.
    It may get some call info added with the integration.. but surely not all the reporting info you might be looking for.
    You may want to review what got into CRM.. and see what you can report there.
    The call logs are stored in the database.. and you'd need to first bust it open directly or via an API.. and I'm not going there here.
    tl;dr: I've done some SP/SSRS custom reports after busting into the PostGRES...
