How to display incoming call?
Discussion in '3CX Phone System - General' started by jacky18, Jul 31, 2008.
  1. jacky18
    Feb 16, 2008
    16
    I have a few pstn line and planning to move them into 3cx via SPA3102
    Currently I have 6 sip phones (SPA 922) calling and receiving calls via my voip provider.
    Here's the real question. 8)
    The requirement is to identify where the incoming call comes from when someone picks up the phone. The reason for this is that the 2 pstn lines are for different business while the other is for another business. In this regard, we need to know how display which line the incoming calls from rather than the phone number of the caller.
    Is this possible? or am I confusing everyone :shock:
    Thanks for your help :mrgreen:
  2. Anonymous
    Anonymous Guest
    Hi there,
    Connect a normal analog phone with display to the line and see if you have caller ID. If not, contact your telco. If yes, provided you have correctly configured the patton you should get caller ID.
    Thanks,
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    yes it is possible and will work,
    To look for is to make sure that you allow the DTMF signal to come through (time wise), if you forward the call to quickly the CLID will not show.
    H.
  4. jacky18
    Feb 16, 2008
    16
    Thanks all
    I shall give it a shot :)
  5. matictec
    matictec New Member
    Mar 31, 2008
    188
    You can define DIDs or MSN with the option "Override incoming Caller ID with DID name". Then you can see the name or number of the DID/MSN on incoming calls in the display of the phone.
  6. amygoda
    amygoda Member
    Sep 18, 2006
    436
    you can add a number in spa3102 pstn page /PSTN CID Number Prefix:91 and 92 in the second device and so on
    or PSTN CID Name Prefix:L1 and L2 in the second device and so on
