how to do an autodial
Discussion in '3CX Phone System - General' started by bblokey, Sep 17, 2009.
  1. bblokey
    Apr 15, 2008
    57
    Does anyone know if it is possible to setup a phone that once the handset is picked up that it would dial an extension?
    10,878
    307
    I know that the Sipura/Linksys/Cisco ATAs will do this using an analogue phone. Haven't actually tried with the VoIP sets but i would think that it is possible given that the options are very similar. It's done in the dialplan, the same way you set up the PSTN side to "DIAL" through to the trunk number of the 3CX when a call comes in on the FXO port.
  3. bblokey
    Apr 15, 2008
    57
    Can't believe I forgot that... This will be easy to test. Thanks for reminder.
  4. voipbaennjer
    Jul 10, 2009
    44
    I think the Grandstream phones have this feature. But I have to check this out when I'm back home...
  5. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    It's a function of the specific phone you have and not a feature of the PBX software. Linksys SPA9xx, Cisco 5xx, and Grandstream phones can all do it. I am not sure about others off the top of my head.
  6. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Please tell me how to do this, I miss my ring back phone from Astroworld so much.
  7. KerryG
    Jun 19, 2009
    960
    What phone?
  8. voipbaennjer
    Jul 10, 2009
    44
    At the Grandstream BT200 / GXP280 and GXP1200 the number to dial can be entered under "Advanced Settings" / "Off Hook Autodial"
  9. tpinnovations
    Jul 30, 2009
    296
    Cisco 7940
    Linksys SPA-3102
    Linksys SPA-942
  10. leejor
    10,878
    307
    In the Linksys devices set up a dialplan the does an immediate call forward. In the dialplan (DP)you are going to use create an entry like...(S0<:301) . Set the line to use that dialplan. When the phone goes off hook it will dial EXT 301. Don't forget to modify the dialplan digits, if necessary, to allow the call forwarded number. make sure you can dial whatever number from the set, first, before you "force" the forwarding. It is done that same way an incoming PSTN call gets "forwarded" to the 1000X number in the 3CX when there is an incoming call on the PSTN port.
  11. tpinnovations
    Jul 30, 2009
    296
    Wow, That is so cool. Thank You for that tip.
