How to download multiple extension recordings
Discussion in '3CX Phone System - General' started by uday.uc, Mar 4, 2015.
  1. uday.uc
    Mar 4, 2015
    5
    Hi i wanted to download multiple call recordings of random extensions
    example : 102,108,120 or range or extensions i have tried but unable to pull out all of them
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    You can access the call recordings one by one as an admin with the web reports tool, or as an user given the rights to download any recordings (Extension properties / Options / Can download any recording).
    Alternatively if you have a physical access to the server you can also browse in explorer to the recordings path set in Settings / General / Global Options / Recording Path.
  3. uday.uc
    Mar 4, 2015
    5
    Pj3cx
    Thanks for your valuable reply
    downloading random recordings one by one is usual and done in normal but i need to access or download multiple call recordings or different ext recordings at a time
