How to enable SRTP for SIP Trunk and SIP Phones?
Discussion in '3CX Phone System - General' started by zyrk, Feb 16, 2018.
  1. zyrk
    Jun 16, 2017
    12
    Hi Guys,
    I see a "SRTP" option for the SIP Trunk but is it something as simple as enabling that? How can I enable SRTP for the SIP Phones? We are using Telnyx as our SIP Trunk provider and Yealink phones provisioned remotely with STUN.
    Thank you!
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,558
    234
    So yes if you want to enable SRTP for the SIP trunk and IP phones then you check the SRTP boxes.
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,398
    186
