How to enable TLS and Secure RTP in v15.5 ?
Discussion in '3CX Phone System - General' started by sip.bg, Nov 17, 2017.
  1. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Extensions for which TLS and secure RTP was enabled in version 14, inherit this setting, when PBX is updated to v.15.5 and traffic is encrypted (works in SP2, as you can already import certificate and private key).
    How about to enable this for another extension, for which this setting was not enabled in v.14 before upgrade to v.15.5 ? Looks like this feature is missing in v.15.5.
    In Parameter settings | DN properties only Secure SIP is available, does this enables secure RTP as well ? Setting Secure SIP value to 1 is not enough.
    #1 sip.bg, Nov 17, 2017
  2. sip.bg
    Nov 7, 2016
    704
    219
    Any more elegant and safe way than editing the backup file and restoring configuration ?
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @sip.bg
    I believe the settings you are looking for are under the phone provisioning tab of the extension. Select the 3CX client from the drop down menu and you should see the Sip transport and RTP mode settings.
    sip.bg likes this.
  4. sip.bg
    Nov 7, 2016
    704
    219
    Thank you :)
    Inherited settings from V.14 are working (TLS, SRTP), but not reflected into extension settings however. Anyway, this setup should work.
