How to estimate minutes used
Discussion in '3CX Phone System - General' started by LukeL, Aug 5, 2014.
  1. LukeL
    Jul 25, 2014
    I need to come up with a relatively accurate number of inbound and outbound external minutes used per month. What is the most accurate and simple way to do this?
    We used Appia and Nexvortex for the past several months but we had consistently bad quality service, no audio, one way audio and severe audio quality problems. I tried Sigmavoip because they offered us a week long free trial and we had no problem at all with them but they don't offer packages. I need to get some exact numbers for an accurate estimate because they charge by the minute and we run a high volume call center. I must also subtract toll free dialed numbers from the minutes count. Any tips or insight will be much appreciated.
  2. naked
    Oct 18, 2013
    8
    If you are using 3CX then the Call reporter provides all the information you need. For excellent audio quality, where possible use a SIP provider's connectivity so that the connection only deals with voice. If that is not possible use a router that has Quality of Service.
  3. LukeL
    Jul 25, 2014
    Thank you Richard. I was thinking of doing something with CSV files to clean up toll free calls. On your response about connectivity, both of our previous providers blamed our Juniper router but we did not have any issue with Sigmavoip and that leads me to believe that the router is just fine and so is our connectivity. I did post a thread seeking suggestions for our router setup in case there is something we missed but my manager today decided to forego a detailed call breakdown for the estimate and we went into production. I hope all stays stable and as well as it was for the 10 days. It looks like the pricing will probably be around the same if not less.
  4. naked
    Oct 18, 2013
    8
    Hi LukeL,
    If they have contention in their network, then any prioritization you do with the Juniper will have minimal affect.
    I wish you well now that it is in production.
