How to exclude internal calls from recording?
Discussion in '3CX Phone System - General' started by aslam, Nov 10, 2016.
  1. aslam
    May 22, 2016
    32
    We are using 3CX phone system 12.5 and want to record calls from extension to outside numbers. We do not want to record extension to extension calls. Is there any way to do it?
    11,113
    329
    As I recall, you couldn't differentiate between inside or outside calls, it was on, or off, for each extension.
  3. aslam
    May 22, 2016
    32
    :( I hope 3CX will look in to this in their service packs or updates since its the one of the feature most call centers will be looking to it.
  4. leejor
    11,113
    329
    In many cases , when setting up Queue agents, multi-line/key sets will be used. The extension to be used for the queue is assigned to the primary key, and additional extensions, as needed, assigned to additional keys. The additional extension(s) can be used for consultation, and not set to record, while the queue extension will be recorded.
