How to export sip accounts of the 3CX Sip Client?
Discussion in 'Windows' started by flaviosrock, Oct 2, 2012.
  1. flaviosrock
    Oct 2, 2012
    Is there any way to export the sip accounts configured on the client?
    Regars,
    Flavio
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    there is .ini file with account setup:
    c:\Users\username\AppData\Local\3CX VoIP Phone\3CXVoipPhone.ini
    p.s. change username with your real username
