How to find number of simultaneous call.
Discussion in '3CX Phone System - General' started by elisha@2020techs.com, Jun 21, 2016.
  1. elisha@2020techs.com
    May 5, 2016
    7
    I am trying to find out if our current license of 16 simultaneous calls is what we need, or if a license for only 8 sim calls would be adequate. Is there any way to look back in the reports and find this some how? Thank you.
  2. 3cxoleg
    3cxoleg Support Team
    Apr 13, 2016
    16
    Hello elisha@2020techs.com,
    at the moment you can only get notified via email if your license has reached the limit. In order to enable this option in your 3CX Phone System in v14, open your Management console >> Settings >> Email >> under Evens check mark "The licence limit is reached" box
  3. elisha@2020techs.com
    May 5, 2016
    7
    Thank you, that is what i need.
