How to force registration*Discussion
Discussion in '3CX Phone System - General' started by leejor, Jul 30, 2010.
  1. leejor
    10,757
    286
    Re: ? How to force registration
    Registration (minimum) time is usually set by the VoIP provider, but you should be able to specify an even shorter time if desired. I've never seen anything to force a registration on a device other than a re-boot/power up. It's not something that you would want to have to remember to do. If a trunk is not showing as registered then you probably need to determine why and correct that problem
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If you change settings related to VoIP provider registration then PBX should refresh it automatically.
    Attached pictures show locations of "Refresh registration" button.
  3. leejor
    10,757
    286
    Yes, sorry, I was referring to a SIP device such as an ATA attached to 3CX.
    "The registrar MAY choose an expiration less than the requested
    expiration interval. If and only if the requested expiration
    interval is greater than zero AND smaller than one hour AND
    less than a registrar-configured minimum, the registrar MAY
    reject the registration with a response of 423 (Interval Too
    Brief). This response MUST contain a Min-Expires header field
    that states the minimum expiration interval the registrar is
    willing to honor. It then skips the remaining steps."
    ( Quote from section 10 of... http://www.ietf.org/rfc/rfc3261.txt )
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Phones are clients of PBX. As a server PBX can not force a client to register.
  5. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Are there any other IP PBX systems that have this functionality? I can't think of any that I have worked with.
  6. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    I realize this is a few days old now but I just wanted to put in my 2c worth.
    From a programming point of view, 3cx cannot force a registration of a client - that is impossible - unless the client already has a way to call this remotely using tcp/ip. So unless Cisco, Snom etc. all put a way to fore a re-register function in their api for each phone (or SIP protocol is changed) then it cannot be done.
    However, the feature of reregistering a phone is possible and available for you via 3cx (sorry if it sounds like i am contradicting the last statement). By definition each phone (or ATA) is web based and most if not all have a web interface. By clicking on the Phone in the phone menu on 3cx you can launch the client interface for the phone. Then you can use the client interface to force a registration (in some cases that means a reboot).
    Hope that helps you?
