How to gain the callee
horse0150
I am from China.I build three extensions in 3cx softphone server and set to transfer the call from 103 extension when the 101 extension or 102 extension is busy.When 101 dial 102,I find transferly successfully,but gain the callee that is 103.I want
to gain 102.What can I do ? Thank you!
Normal, "gain" in this context is increase the volume.
But that does not make any sense either is it, matt?
H.
Okay, this is rough guess;
"I am from China. I created 3 extensions in 3cx and set it to transfer the call to extension 103 when 101 or 102 are busy. When 101 dials 102, it transfers successfully, but I get 103, not 102."
either way, I think gain = get in this context, which makes sense. I'm just not sure about the "callee" bit, whether he means he gets the callee that's on line 103, or callee = extension?
Get 3CX - Absolutely Free!
3CX
