How to get all calls to dial out number withheld?
Discussion in '3CX Phone System - General' started by jmd87, Sep 24, 2014.
  1. jmd87
    Sep 23, 2014
    Is there away to get all calls to automatically call out number withheld? I put *5 when dialing out and that works great but want it to automatically do it.
    Is there away please?
    Kind Regards
    Joe
    10,769
    286
    Depending on the type of trunking you are using, you could prefix the required (by your provider) code on all outbound calls. Given that many people will not accept, or they have systems in place that will not accept blocked calls you could send a single, non-returnable number, on your outbound trunk.
    If it is just a single extension, then an outbound number can be set in that extensions options.
