How to get caller number
Discussion in '3CX Phone System - General' started by kousinovaliskostas, Aug 17, 2016.
  1. kousinovaliskostas
    Aug 17, 2016
    6
    Hello
    I'am developer and i want to make an app to read the caller number to show on screen.
    Is it possible to do that?
    I mean is there any way the 3cx to send the caller number somewhere so i can grab it?
    11,293
    361
    Not really clear on your question you will have to explain in a bit more detail what you are trying to accomplish.
    Do you mean "read aloud" an incoming caller ID number, for one set?
    In what form, do you want the caller ID? There have been devices (over the years) available, that will collect CID (Bell core, and perhaps others), and send as serial data.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    444
    20
    API :?:
    CDR
    topic44462.html
  4. kousinovaliskostas
    Aug 17, 2016
    6
    In Elastic there is a feauture that the program sends over http the calller number, so i made a program to grab it and save it to my database and do other things with it.
    Is it possible with 3cx? Or is there soemwhere that 3cx stores the caller numbers so i can take fron there?
