How to get CallerID number?
Discussion in 'Call Flow Designer' started by VictorSP, Jun 15, 2017.
  1. VictorSP
    Sep 6, 2016
    61
    10
    We've been playing in our lab with different scenarios on Call Flow Designer. One of them is get CallerID from incoming call and check it with a CSV file, but I don't know how to make this action of getting CallerID info. Is there any option or feature for that?
    Regards,
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hi @VictorSP,
    The caller ID is available in the session.ani variable. Please check it and let us know if you have any questions.
    Kind regards.
    VictorSP likes this.
  3. VictorSP
    Sep 6, 2016
    61
    10
    Thanks a lot, @edossantos. Working with that variable the scenario progress. Quite good!
