How to group ports in 3CX for Patton gateway
Discussion in '3CX Phone System - General' started by aslampa, Dec 9, 2016.
  1. aslampa
    Mar 18, 2016
    42
    We have 4 port Patton Gateway and we have 2 numbers with multi line (Means one number have two line).How we can configure it
    I am looking for something like
    In 3CX, I want to create 2 SIP trunk with 2 ports/trunks each.
    SIP Trunk 1 need 10008 and 10009 - Patton 0/0 and Patton 0/1
    SIP Trunk 2 need 10010 and 10011 - Patton 0/2 and Patton 0/3
  2. ALuisPV
    Mar 7, 2016
    28
    Hi ,
    I think that one good solution is to have an unique SIP Trunk between the Patton and 3CX and do this custom configuration of ports in the Patton ifself.
    Using this solution, in 3CX, you can have the 2 DIDs associated with the SIP Trunk of the Patton and you don't need to worry about ports in 3CX. You directly configure Incoming Calls in 3CX. For Outgoing Calls, you only need to send to the Patton all the calls that this gateway must process.
    You must configure the Patton manually to implement this solution (group of ports, outgoing calls, etc.)
    Best Regards.
