How-to: Hang up via Digital receptionist
Discussion in '3CX Phone System - General' started by packhamster, Apr 20, 2007.
  1. packhamster
    Apr 19, 2007
    First of: This is an amazing piece of software! Thank you all @ 3CX (and all the smart people here in the forum)!
    My question: I am building an automated support system using the digital assistant and virtual mailboxes. In other systems I have worked with there is an 'End call' option under the action drop downs. It's used at the end of a tree like "To end this call press 9". What follows maybe a prompt like "Thank you, good bye" which action would be to end the call. Is there such a function in 3CX?
    Any help/hint would be much appreciated!
  2. Anonymous
    Anonymous Guest
    I have not spend much time with the IVR but here is my thoughts on this.
    When you record a message or want to cancel the call you get the messasge:
    "Press pound to record your message"
    Than
    'Message recorded"
    I assume you can use this functionality.
  3. packhamster
    Apr 19, 2007
    Nope
    Thanks, I saw that too and tried, but unfortunately it doesn't work
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,936
    250
    Thanks for your nice feedback!
    Currently there is no such option, callers can just hang up the phone. However we will consider your suggestion as a feature request for future versions.
  5. Alexander
    Nov 10, 2006
    73
    Hi !
    You can use '#' (pound) to cancel a Digital Receptionist dialog. So you can add somethin like 'press pound to disconnect...' to you Digital Receptionist's wellcome prompt.
