How to have multiple Fax Ext. with int. Faxserver[Solved]
Discussion in '3CX Phone System - General' started by dab, Nov 4, 2009.
  1. dab
    dab
    Nov 1, 2009
    67
    I'm using Verison 8 and like to have multiple (SIP) Fax Targets with the integrated Faxserver.
    Is this possible? - Thanx
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,442
    61
    Re: How to have multiple Fax Targets with integrated Faxserver
    Do you mean - you want to send simultaneously faxes using our fax server? If yes, on which OS fax sending module is installed? I'm asking because not all OSs allows this.
  3. dab
    dab
    Nov 1, 2009
    67
    I'm using W2k8R2 with multiple Single-SIP-Numbers from Provider, no trunking.
    Primary for incoming, for the moment two of them are pointing to the "default" Fax-Target 88. What I like is that Number a -> 88 and number b -> 89? With this i can redistribute the faxes to different emailaddresses. If the "new" 3CX faxsolution for outgoing fax will be available I like also send faxes from the different targets.
  4. dab
    dab
    Nov 1, 2009
    67
    I was some kind of blind, create multiple extension with different default email addresses and configure the VOIP-Provider or Inbound Rule to "Send fax to email of extension" and select the extension you wish.
    The outgoing part will be a different story ...
