How to hide caller id in 3cx system?
Discussion in '3CX Phone System - General' started by Shihao, Mar 19, 2018.
  1. Shihao
    Feb 28, 2018
    We are trying to connect our ip phone to 3cx system. Our phone has CLIR feature, which means the caller's id can be hidden from the called to see. But on 3cx, INVITE with anonymous caller is rejected. Both the caller and called are registered to 3CX. Could you please tell us, how could we do to hide the caller's id?
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    995
    153
  3. Shihao
    Feb 28, 2018
    Thank you for your information. But the links above seem talking about outgoing call through trunk. How about local calls? And on our system, if you dial *5xxxx, it is rejected with 404.
  4. eddv123
    Aug 15, 2017
    995
    153
    By local calls are you talking about extension to extension?
    The rejection you are seeing is probably due to you outbound rules please check you have one that matches.
    You will need to strip the preceding digits obviously.
  5. Shihao
    Feb 28, 2018
    Local calls means extension to extension without a trunk or bridge.
  6. eddv123
    Aug 15, 2017
    995
    153
    Exactly why I wanted clarification - can you confirm your user case ? IE: why would you want to do this ?
    Are you trying to multi tenant 3CX by any chance ? as this is the only reason I can think.
  7. Shihao
    Feb 28, 2018
    It's the existed feature of our phone. We just try to do the compatible tests. If 3cx doesn't support it, we can put it in our test report.
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,997
    190
    why would you want/need to block id of an internal call? just curious...
