How to insert pause in outgoing rule
Discussion in '3CX Phone System - General' started by MichaelD, Aug 17, 2010.
  1. MichaelD
    Mar 27, 2010
    36
    Hello. I need to enter a pause in an outgoing rule. How do I do that?
    I am using the Patton 4114.
    MichaelD
    11,105
    329
    SIP doesn't allow for pauses as all digits are sent at one time. To put in any sort of pause would require an analogue set with an ATA. The set would have to have some sort of number memory that allowed for the insertion of a pause. The first part of the number would be sent as a SIP message and then the remainder sent as DTMF to the far end after the connection was established.
