Solved How to insert purchased license over a free licenze
Discussion in '3CX Phone System - General' started by perdicaro, Jan 31, 2017.
  1. perdicaro
    Jun 1, 2013
    26
    I installed the iso of the 3CX system for debian linux, everything works properly, I entered the free license key, but now after a few days I decided to buy the 3cx official license, go to: Settings / license / editing and the box can not enter the number of licenses purchased; I have to reinstall the entire operating system?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You need to reinstall the PBX, backup it without license key, install a new PBX, enter new license key and restore backup. You may need to release FQDN record if the same one needed
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Perhaps some partners should emphasize
    As an End User, you must present your key to the 3CX Partner for the Upgrade order to maintain your installation and FQDN
  4. perdicaro
    Jun 1, 2013
    26
