How to Install & Configure 3CX in Windows 2008 R2 Server
Discussion in '3CX Phone System - General' started by gocheez, May 21, 2011.
  1. gocheez
    May 21, 2011
    Hello dear All,
    I try install 3CX on windows 2008 server R2 with DOT NET 4.0
    its perfectly install and i create 3 ext. done
    But after that the ext. is not register, I don't no why.
    I try to find out on google & 3CX web site i can't.
    Please help me how this Ext. register & work ?
    Regards
    Goche
  2. dab
    dab
    Nov 1, 2009
    67
    Have a look at your firewall settings, are the 3CX created rules enabled?
    Set the logging level of your 3CX to Debug (Settings/Advanced/Logging Level) and post your log during the registration attempts with a
    Code:
     for better readability.
  3. jamie2000ukuk
    Mar 1, 2011
    12
    I had this problem is to do with the windows firewall you have to allow the ports with in the windows firewall
  4. Sha1a
    May 18, 2011
    15
    I have found if you open windows firewall settings pannel up on your windows server 2008 (same as I am currenty running) then run the firewall checker in the 3CX administration console or web portal. The "keep blocking" or "unblock" option will pop up... You can then click unblock... Fixed it for me, when I first installed.
    Hope this helps.
  5. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Also ensure you disable IE SEC and install Desktop Experience
