How to install NTP server on Debian?
Discussion in '3CX Phone System - General' started by Edi Kojsi, Nov 29, 2017.
Tags:
  1. Edi Kojsi
    Nov 28, 2017
    30
    I have a customer where the phones don't have access to internet (for security reasons).
    How to install NTP server on Debian 9, so the phones can adjust time from it, the phones and PBX are in different local-area subnets (layer 3 routing, without NAT).
  2. Corné Hokke
    Nov 3, 2017
    5
  3. Edi Kojsi
    Nov 28, 2017
    30
    Thank you Corne,
    should I modify also IPtables to allow traffic to port 123 UDP from other local subnets or to modify restrict statement into NTP configuration file?
    In 3CX parameters, the PBX address is set as an NTP server for phones, I guess they have a firewall issue to get time from 3CX server?
  4. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Perform the following steps:
    1. Install ntp server:
    apt-get install ntp
    2. Edit /etc/ntp.conf and configure broadcast (uncomment it and adjust the network):
    broadcast 192.168.123.255
    3. Execute the following command and check status:
    systemctl restart ntp
    ntpq -p
    4. Configure firewall (iptables):
    iptables -A INPUT -p udp --dport 123 -j ACCEPT
    iptables -A OUTPUT -p udp --sport 123 -j ACCEPT
    5. Make changes permanent (in order to be active after reboot):
    /usr/sbin/netfilter-persistent save
    update-rc.d ntp enable
    That's all. Should be enough.
    You need to set also in 3CX the local IP address of 3CX as NTP server (in Settings | Parameters) and reprovision phones in order new NTP server settings to take effect.
    #4 sip.bg, Dec 18, 2017
    Juan Marriott and Edi Kojsi like this.
