How to log a hardphone into a queue(s)
Discussion in '3CX Phone System - General' started by mWz, Nov 24, 2010.
  1. mWz
    mWz
    Nov 24, 2010
    6
    Hey,
    How do you log a Linksys SPA941 into a queue or queues if there is more than one queue associated with an extension?
    Cheers.
  2. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    According to the documentation...
    Dial *62 to log the extension into all the Queues that the extension is a member of.
    ... so that implies that the dial code will log you into ALL queues, however, I can't be certain of this as I don't use queues just ring groups and digital receptionists.
  3. mWz
    mWz
    Nov 24, 2010
    6
    Hey, Thanks for your response.
    Can you point me to the documenation that refers to this - is it the 3CX docs or the phone docs??
    Many Thanks.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    This is a 3cx feature, the manual may of the 3CX softward may be found on our download page. It is in the section called dial codes. Please note you may also sing in ot the queues from the managements console, the myphone page and the 3cx assistant.
  5. mWz
    mWz
    Nov 24, 2010
    6
    OK, found it - I hadn't read the extension manual!!
    Many Thanks all.
