How to make 3CXPhone default dialer in Windows
Discussion in 'Windows' started by gary2seven, Apr 5, 2013.
  1. gary2seven
    Sep 18, 2009
    48
    How can I make the 3CX phone my default dialler in Windows 7 ?
    I have tried changing the registry entry ;
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Telephony\HandoffPriorities::RequestMakeCall
    but still Skype pops up when I click a phone link.
    Gary.
  2. John_Vella
    Jul 8, 2013
    Pardon what may sound like a stupid question, but are you talking about Windows 7 on your PC or is this Windows 7 Phone?
  3. gary2seven
    Sep 18, 2009
    48
    Windows 7 on a PC.
  4. John_Vella
    Jul 8, 2013
    This might be worth a go... I read somewhere else about someone having trouble with Skype and Outlook, (but it was the same problem... Skype hijacking the dialler) and it worked. I'm quoting from the other forum:
    You might have to uninstall and re-install Skype AND 3CX, but that doesn't sound like too big a deal if it fixes the problem.
    Hope this helps. Let me know how you get on.
