How to make Cisco 7940 MWI works?
Discussion in '3CX Phone System - General' started by tonykong, Aug 29, 2007.
  1. tonykong
    Aug 29, 2007
    I am working for a IT consauting company in Canada. We have some spare Cisco 7940 SCCP phones. I re-image 7940 to SIP v6.0. They are working fine with 3CX Phone System Version3.1.2434.0. :p :p
    I have enabled the MWI in "SIPDefault.cnf" file as below.
    # Dialtone Stutter for MWI
    stutter_msg_waiting: 1 ; 0-Disabled (default), 1-Enabled
    But I still can't make the MWI light work. Could some one help?
    thanks a lot!
    Tony
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    MWI is disabled in free version.
