How to make Door Phone Ring over Paging adapter?
Discussion in '3CX Phone System - General' started by AZ-Brad, Apr 11, 2018.
  1. AZ-Brad
    Jun 29, 2017
    20
    I have a location that has 2 door phones, Algo 8201's on 3cx v15.5 latest. Those work great. They are set to dial the ring group when a button is pressed. The CID shows what door is calling and the phones ring.
    They also have a Cyberdata Sip Paging adapter v3.1 that does the overhead paging. It works fine too. However they are requesting that I the Paging Alert somehow that a door button has been pressed. Anyone know what to do here as if I add the cyberdata to the ring group, it will answer. So not sure how to make the setup happen?
    Thanks!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,003
    191
    We registered our Cyberdata Speaker using the "Night Ringer" setting and put it into the ring group. It is part of our backline that gets used by employees on the weekend and after hours.
    I do not know if the Sip Paging device has this available?
  3. AZ-Brad
    Jun 29, 2017
    20
    I saw an event called night ringer. How did you go about setting that up?
  4. craigreilly
    Feb 1, 2012
    3,003
    191
    I set this up manually.
    SIP Server: 3cx Server
    User ID/Authenticate: from the Extension credentials
    Password: from the Extension credentials
    The SIP Config tab is not used.
    I also use Multicast for Paging thru this device.
    Multipurpose.
  5. AZ-Brad
    Jun 29, 2017
    20
    Found a similar menu. Thanks.. that is what i needed!
  6. craigreilly
    Feb 1, 2012
    3,003
    191
    good deal!
