How to make the IPPBX support G.729 Codec?
Discussion in '3CX Phone System - General' started by praneethkatru, Sep 24, 2007.
  1. praneethkatru
    Sep 20, 2007
    i have my VoIP provider supporting G.729 codec which does not need more bandwidth.
    Can we make the IP PBX support G.729, if so how it can be done.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    The current 3CX IPPBX still not support G.729 and not allow to add-in external codec as well.
  3. Anonymous
    Anonymous Guest
    Most likely they will add it in the future......
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I just found out that my voip providor accepts g729 too. I would really like this added as well. DSL is horrible here for upstream bandwidth.
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,973
    283
    You'll have to use a provider that uses GSM, ilbc or speex. G729 support is not planned.
  6. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We can provide an information how to write a codec's plug-in for Media Server. Than one who want G729 support needs to pay G729 royalty/licansing fee and learn C++ to make such plug-in. Than one may use it as necessary.
