How to manually delete call recordings
hilal esa
I am new to 3CX.
How does one delete call recordings.
HE
Go to the directory where the calls are stored, select the call you want to delete, and delete it.
To find the directory (recording path) go to Settings >> General >> Global Options.
By deleting the files manually will I not mess up the database entry in the 3CX Phone System database. I was worried that each file is listed in the database.
No, it won’t mess up the database. The PLAY links will remain visible in the database, but this does the database any harm.
Getting Started - Admin
julian1234
Get 3CX - Absolutely Free!
3CX
