How to me 3cx treat all connections as internal?
Discussion in '3CX Phone System - General' started by djboxny, Aug 11, 2010.
  1. djboxny
    Aug 8, 2010
    42
    I have a HP dl380 connected directly to the Internet with a static ip. My server has 2 nics paired to that static ip. Everything works great locally, how can I make 3GS treat all devices as local since most extensions will be connected from another locations
    10,772
    286
    I don't see how you could if the extensions are registering from another public IP + port.
  3. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    3GS?
    I dont understand your application here. Functionality wise, remote and local phones function the same. Can you explain why you are looking to do this, and perhaps we can suggest another method/workaround?
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    even if your nic card is connected via a public IP, it doenst mean that the phone is local. As explained previously a phone that is local or remote bares no diffrence, the only diffrence might be that you do not have video, and provisioning. I have never seen an attempt to remotre provisiong a phone over a public IP, and im not sure if it would work. Do you have any specific requirments?
  5. djboxny
    Aug 8, 2010
    42
    Well I just reads article from 3cx about internal and external devices. But u guys haves answer my questions thanks
