How to Pickup / Transfer to Voicemail in v12
Discussion in 'Windows' started by BobD, Jun 25, 2014.
  1. BobD
    Apr 25, 2011
    27
    What happened to the ability to right-click on a call and either Pickup or Transfer the call to Voicemail ?
    I can right-click, Transfer, enter my extension and click OK but that's "too many notes". I want to right-click, Pickup like in v11.
    When I'm on the phone and see that there are calls in the queue, I often need to send the call to voicemail because I know that I'm not going to be free for a while. Where'd the feature go to send a caller to voicemail?
    Bob
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Unfortunately this is how it is in v12, it requires right click on the queue call / transfer / enter extension / choose your extension with voicemail icon.
    You can also right click / park call / then drag it from the active calls and drop it on yourself to have it ringing and choose forward to voicemail.
    I'd suggest to post this as a feature request on 3CX Ideas if you'd like it simpler : http://3cx.com/ideas
