How to prevent an extesion from calling out
Discussion in '3CX Phone System - General' started by rhett, Sep 20, 2007.
  1. rhett
    Sep 7, 2007
    12
    Hello Group,
    Is there a setting that i can use to prevent an extension from calling out?
    Rhett
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Create an outbound dummy line that goes no where and wouldn't register, then create an outbound rule for the extension(s) to be blocked and point to dummy line without backup provider.
