how to receive an external ip with sip transparent router
Discussion in '3CX Phone System - General' started by klamfeldt, Feb 11, 2008.
  1. klamfeldt
    Feb 11, 2008
    Hello
    first i must say that the PBX looks like a wonderful application, but unfortunately i can't use it since I have a sip-transparent router!?!?!? I've got a ix67 surfinbird which can act as a sipserver. the ix67 does not like stun at all (since it's sip-transparent). So do any one know how to "tell" the application "i dont need the stun use xxx.xxx.xxx.xxx as external ip or even better use my.dnsaddress.com". I've tried to set LocalSubnets in the ini_file to 192.168.0.40/50,xxx.xxx.xxx.xxx but with no success.
    Klamfeldt
    ps I use the beta version
    Edit How to a turn off/restart the PBX? i tried to kill it and restart the 3CXPhoneSystem.exe
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    You can restart the 3CX services in Services and Application
    Right click My Computer
    Manage
    Services and Applications
    Services
