How to remove old phone from extension provisioning?
Discussion in '3CX Phone System - General' started by richardwvm, Jan 20, 2016.
  1. richardwvm
    Dec 21, 2015
    27
    I need to remove my old phone from my extension provisioning settings. At the moment I'm listed as "Multiple Phones" on the Phones tab, so I can't re-provision.
    Have I missed something obvious?
    Regards,
    Richard.
  2. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    Hi Richard,
    You edit the extension. There in the "provisioning tab" there are sepetate sub-tabs, one for each phone.
    You choose your old phone. You select " " (blank, no phone model selected) as phone model in the dropdown and deletee the MAC and save/ apply.
    Then you can reprovision the phone without the ( MAC adress already assigned to a different extension)
    Best regards Frank
  3. richardwvm
    Dec 21, 2015
    27
    Hi Frank,
    Many thanks that worked a treat, although a delete button might be better!
    Regards,
    Richard.
  4. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    I added a feature request:
    http://www.3cx.com/forums/delete-and-reassign-for-phones-already-assigned-o-an-extension-43929.html
