How to remove REC tab from Reports (call logs)
Discussion in '3CX Phone System - General' started by parthasarathy.r, Jul 17, 2015.
  1. parthasarathy.r
    Jul 17, 2015
    How to remove REC tab from 3cx reports -> Call Statistics Report -> Call Logs ?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    REC column will always be visible but restrictions can apply on the links listed, admin sees recordings for anyone.
    However a user will have restricted access to his own recordings by default, by creating access through extension properties / Options / Allow 3CX Web Reports Access, and not ticking "Can download any recording" below.
  3. parthasarathy.r
    Jul 17, 2015
    Hi PJ,
    Thanks for your reply, The play button shows even after deleted the audio. How to remove play button in the report in-case of audio not available in the server?
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    How was removed the recording? file delete from explorer ?
  5. parthasarathy.r
    Jul 17, 2015
    Yes deleted from the folder. (c:/program data/3cx/data/recordings/egrecord.wav).
  6. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Unfortunately the recording path is stored with the call log in database and therefore deleting file doesn't deletes the record.
  7. parthasarathy.r
    Jul 17, 2015
    Then how to remove it. Is there any other option?
  8. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    One could delete recording from 3cxphone logged as the said extension, but the outcome is the same in v12.5.
