How to remove the 'please hold'
Discussion in '3CX Phone System - General' started by randomness, Nov 3, 2010.
  1. randomness
    Oct 13, 2010
    10
    I've set up my first digital receptionist, and applied my custom mp3.
    Now, how do I get rid of the 'please hold while I transfer your call'? I could almost live with being able to change it to one with a UK accent, but ideally want to get rid of it altogether.
    Also, any pointers on resampling my mp3 files would be appreciated - my 's' sounds are a little bit 'blowy' heard via the phone, yet they sound fine when you play the mp3 file on the computer.
  2. Discovery Technology
    Apr 19, 2008
    278
    You could try re-recording an empty .wav file and replace the please_hold.wav file in the ivr prompts folder.
    If you're running Windows 7, this would be found at c:\programdata\3cx\data\ivr\prompts\sets then the set you're currently using.
    There are also a few documented references on this website that cover the suggested format of audio files that work the best through phones, however for ease of reference, try saving your recordings in wav format as follows: PCM, 8 kHz, 16 bit, Mono.
    You could also try reducing the volume of the recorded file as loud recordings also cause a slurring or crackling sound on the s.
  3. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    What program are you using for audio files?
    I recommend Audacity as it gives better quality and use the settings mentioned in the post above and you should have no problem).
  4. randomness
    Oct 13, 2010
    10
    Thanks - dropping the file to 8k has massively helped the audio. I'm using Adobe Sound Booth on the mac.
    I've tried finding please_hold.wav but no joy. It's Windows XP, and having searched for 'IVR' I've come up with two locations:
    c:\program files\3cx phonesystem\data\ivr\cfg
    c:\program files\3cx phonesystem\data\ivr\temp
    Any ideas?
  5. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    This may give an idea of your file path for XP. This is my path on Windows 2003: Documents and Settings\All Users\Application Data\3CX\Data\Ivr\Prompts\Sets\43E89581-DAD8-B6F4-7660-15D48B5E6026
    I hope this helps
    Richard
