Solved How to reset my 3cx instance and start again with the configuration from scratch?
Discussion in '3CX Phone System - General' started by ovizii, Nov 21, 2017.
  1. ovizii
    Nov 20, 2017
    55
    I'm running it on a self hosted Debian 8 v-server and I'm sure I messed it up with my experiments. I'm now ready to actually start using it but I'd like to reset and start from scratch.
    I could of course setup the server from scratch again or is an "apt-get uninstall --purge
    3cxpbx" enough to delete all traces?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    apt-get uninstall --purge 3cxpbx - Removes all and all dependencies with it.
    Jim Kubicek likes this.
  3. ovizii
    Nov 20, 2017
    55
    Thanks for confirming. Do you happen to know how to mark this thread as solved?
  4. StefanW
    Jun 2, 2009
    1,222
    93
    Thread Tools -> Edit - Suffix - Solved, i shall do it for you ;-)
