Solved How to restart service
Discussion in '3CX Phone System - General' started by Kevin_wu, Jul 21, 2017.
Tags:
  1. Kevin_wu
    Jul 6, 2017
    5
    How can I restart service to take changes(change the active log level from low to Verbose) affect?
    I am using the PBX in-cloud which was installed via PBX Express Tool.
    Thanks!
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Kevin_wu,
    To restart the services, go to Dashboard > Services > Select all (one by one) and click Restart.
  3. Kevin_wu
    Jul 6, 2017
    5
    Hi Panayiotis,
    Find them now, thank you:)
