How to Run Websites and 3CX Simultaneously on One Server
Discussion in '3CX Phone System - General' started by Tony Lin, Mar 13, 2018.
  1. Tony Lin
    Nov 15, 2017
    Have anybody try this?
    I installed LNMP before 3CX, but nginx service report error when 3CX has been installed.
    80/443 port for LNMP, 5000/5001 for 3CX.
    I could login LNMP page, can't login 3CX page.
    Does anyone know how to solve this problem?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    you should not do this, run your LNMP on one and 3CX on another.
  3. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    My office server runs 3CX, php7, Wordpress, MySQL, postfix, dovecot, wine, and a pretty GNOME desktop. I assume you use separate configs for 3CX and your other website? I know I do. I will say I don't run ssl on my website.
  4. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Running other services on the same server as your phonesystem and especially other webservers/websites is a recipe for disaster and far from ideal. No matter if you are running separate configuration for each server/user, or harden the system overall, you put everything at great risk.
    craigreilly likes this.
  5. netpro2
    Apr 1, 2014
    11
  6. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    I like to live on the edge, but in reality Linux is hard to crash.
