How to Search 3cx Forums using Google
Discussion in '3CX Phone System - General' started by mfaster, May 23, 2008.
  1. mfaster
    Jun 19, 2007
    21
    I like using the forums for help with the community, although I do get a little frustrated when using the Forum search bar...
    So I use Google to search the forums with better results. From the Google search bar:
    <search term(s)> site:www.3cx.com/forums
    example:
    registration site:3cx.com/forums
    you can also use google boolean etc in the search tems
