How to see line ID in version 15/15.5
Discussion in '3CX Phone System - General' started by sip.bg, Nov 13, 2017.
  1. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Creating / Editing a SIP trunk is not showing line ID, e.g. 10000, 10001, visible in previous versions.
    In the same time you need this number when importing DID numbers, looking at activity log, etc. Having several lines makes the task hard enough.
    Is there an easy way to see assigned line ID to SIP trunks / PSTN gateways / bridges ? May be a column with line ID missing in status windows.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @sip.bg
    I think this is one for the Ideas section as this is not visible anywhere in the PBX. Easiest way is to export a DID associated to a trunk and see the trunks ID. You can also use the search bar in the SIP trunk menu and see if you can locate the trunk with it's line ID. For example if you type 10000 it will tell you which trunk is 10000.
    complex1 likes this.
  3. sip.bg
    Nov 7, 2016
    704
    219
    Searching for 10000 is at least helpful.
    Thanks.
