how to set call forward by phone?
Discussion in '3CX Phone System - General' started by SY, Mar 30, 2010.
  1. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Are you asking about "my phone" portal?
  2. SY
    3CX Support
    Jan 26, 2007
    1,825
    You can use myphone portal to configure your extension (including forwading rules)
    Alternative - use features provided by your phone. Some phones can be configured to ask PBX to redirect call to alternative destination.
  3. callworth
    Mar 11, 2010
    7
    What phones are you using? Most of the phones I've run into have that feature and will work with 3CX. That's not to say that all of them will however.
    I could be wrong, but I'm not aware of any dial codes to set call forwarding with 3CX.
  4. pdrw
    Apr 8, 2010
    I think he's talking about 3CXPhone the softphone to your pc.
    I got that question too, it seems impossible to automatically forward calls on the softphone, at least no option allows that.
    Do we need to forward calls on SIP server? Otherwise I'll have to use another softphone (i like 3CX).
  5. mfm
    mfm Active Member
    Mar 4, 2010
    641
    At this time the 3CX Phone does not allow it, you may post a feature request in the feature request section of the forums. You can as Stephan suggested use the myphone portal this will allow users to set forwarding rules for their own extension. All they need is there pin code.
  6. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Not sure what you mean are you speaking generically or? Im asking as it may be a bit misleading to some users.
  7. pdrw
    Apr 8, 2010
    My problem is I only use 3CX as client softphone and it has no call options, also i can't access myphone portal cause it's only the client side, our SIP uses another software.
    So it can't be done at all from client side only? Do I need to put a rule in the server?
    Thanks for the answers.
  8. mfm
    mfm Active Member
    Mar 4, 2010
    641
    So you are not using 3CX PBX? Maybe the PBX you are using has something similar to the myphone portal we offer? Call forwarding at this time cannot be done from the Softphone. You may post a feature request in the feature request section of the forums.
  9. pdrw
    Apr 8, 2010
    Thank you mfm, already posted a feature request.
    It'd be great if 3CX implement this.
  10. amnart@mvcoms.com
    Sep 2, 2014
    If 3CX Phone connecting with voice gateway that not support feature code or dial code, how can I use dial code about call forward or other ad ons to enable it?
    Amnart
  11. leejor
    11,077
    324
    Are you talking about a dial code to activate/de-activate a call forwarding feature in 3CX...or, activating/deactivating a call forwarding feature from your provider, via a gateway? It would seem that the former does not yet exist, but the latter may be possible, depending on the digits that your provider requires. Most gateways will not pass on * or #, as dialled, but in some cases there are work-arounds.
