How to set Outbound Caller ID on Fax Extension.
tino
I have an inbound rule that routes my fax number to my fax extension.
For other extensions I use the "Outbound Caller ID" field to set my outbound number to my VOIP provider.
For the FAX Extension, I cannot set the Outbound Caller ID. Any ideas how to make my FAXes come from my FAX number? (E.g. Set the Outbound Caller ID field for FAX extension?)
Tino
hello
You can set a rule for the output fax
Are your faxes going out using the same VoIP provider (same routing) that your other outbound calls use?
Getting Started - Admin
Ramishvohrw
Get 3CX - Absolutely Free!
3CX
