How to Set Password to restrict International calls
Discussion in '3CX Phone System - General' started by Umer, Mar 29, 2012.
  1. Umer
    Mar 29, 2012
    Hi everyone,
    How can i set password on my 3cx server v9 or on my Linksys Ip Phone SPA so that if any one dials an international number it will ask him for a password, can any one help me on this.
    10,362
    227
    There is no provision (in 3CX)to ask for a password (Billing codes can be inserted after a dialled number http://www.3cx.com/blog/voip-howto/dial-codes/ ). What you can do is create outbound rules that require a prefix when calling any particular number, international or national.
    The outbound rule(s) could apply to one or several extensions, each could have their own unique prefix, that is required to call international.
    See...outbound-pin-code-20163.html#p101665
  3. Umer
    Mar 29, 2012
    But the problem is that this unique number can be seen on the redial list so any other person can see what to dial for International calls so my problem will remain the same. :(
  4. leejor
    10,362
    227
    Yes, that is true.
    Do the employees have a habit of scrolling through other peoples phones looking for dialled numbers (that would seem quite nosy) , or is this a shared phone? If it is shared, then you may want to think about providing a set with no display (or no redial feature). Or, an analogue set (ATA) with only a call display unit for incoming numbers.
  5. efounco
    efounco New Member
    Sep 28, 2011
    148
    Haha, you midazwell' write the code down on a post-it and stick it to the phone...
    I know you can restrict International calls using a group. Assign the extension to a group and then prohibit that group from making international calls through an outbound rule. Unfortunately, this will prohibit all international calls made from this phone/group.
  6. grodinj
    Jun 23, 2010
    6
    I have 3CX version 7. In my outbound rules, I can only set which route the call should go through (My Sangoma a101 is the only option) and then I can add or stip out numbers. How do you use an outbound rule to "require a prefix"? Is this only available on a later version of 3CX?
    Thanks,
    Justin
  7. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    You want to make a international call from the UK to the US.
    You would normally dial 001 (xxx) xxx xxxx.
    So now think of a number lets say 456.
    First make a entry in the out bound dial plan for numbers beginning with 001 by entering 001 in "calls to numbers starting with" and set the route to either "BLOCK CALLS" or a route that will fail in previous versions. Now no one on the system can make a call to the US.
    Then make a second entry with 456 in "calls to numbers starting with" Then the route to the provider you use for international calls with "strip Digits" set to (3).
    Now to dial the call you enter 456 001 (xxx) xxx xxxx. The dial plan would then strip out the 456 and place the call correctly to the service provider. Only users who new the access code 456 would be able to make international calls.
  8. leejor
    10,362
    227
    You can create an outbound rule that is applicable to certain extensions, or all, it;s up to who you wish to restrict. If you currently had an international rule that handled 9011, as the prefix, then stripped off the 9 (access digit), before sending... you could create a rule 663865011, that then stripped off 6 digits before sending the 011xxxxxxxxxx out on the trunk. So...663865, now becomes the "PIN" that the caller has to dial before the international number.
    As I said, that rule could apply to just one extension or everyone. Of course, if the old rule was still in there, you would have to set it to apply to everyone BUT the extension that had to dial the "special" prefix.
    If there weren't too many, you could create a different rule for each extension, so that everyone had their own "code". If they thought they would be tracked, they would be less likely to let it slip to anyone else. You could even let them choose their own access number, but its' best to have them all start with the same digit, keeps the dial plan a bit less complicated and less risk of a conflict with an extension number.
