How to set Two Spa 962 share line
Discussion in '3CX Phone System - General' started by siu612, Feb 10, 2010.
  1. siu612
    Feb 10, 2010
    Hello all,
    I have two spa 962 and want to share line from one of the main ext. on spa 962 to another one of the deputy spa 962. I tried to follow the manual to do that but not sccess and have a icon make red "X" then the red flash ligh is flashing. So i can not use this ext. Which method to do this share line?
    James
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I hope you mean you want the same extension on both phones. In that case you have to go to the web interface of the phone and manually configure the extension. You will need to put the IP of the 3CX system into the Proxy field, the SIP ID and Password into the appropriate fields, it should reboot and register. If not, you probably have a typo.
  3. siu612
    Feb 10, 2010
    I tried to do on the webpage and follow your steps but not success. And in the INFO tab display “Failed Not Reachable” on both SIP phone. Do you have any idea to fix this problem?
    James
  4. leejor
    10,732
    277
    Get one set to register (work) first. Once you have that working, put the same settings in the second phone.
    Sharing the line, in SIP , means that more than one set can receive calls made to the same number, or make calls that show up from the same number. What you can't do is have both people pick up their phones at the same (approx) time and all talk to the caller at the same time as you would with an analogue extension.
